I have a 05 Dodge dakota with the 4.7 V8. My problem is that I am getting a p0104 code which is supposed to be a Mass Airflow sensor Intermittant. The engine has no Mass airflow sensor, it has a MAP sensor which is a different code. I could use some insight.
what are the simtoms is the idle like when you driving feel like you have an engine brake or like going to fast in a low gear? if is that change the MAP Sensor but the code should be P0108
Users browsing this forum: Yahoo [Bot] and 8 guests
