It is currently Fri Nov 20, 2009 8:56 pm
 Post subject: 99 Ford Ranger 2.5L P0402 excessive egr
PostPosted: Thu Jan 29, 2009 7:39 pm
My egr valve doesn't hold vacuum. I thought P0402 excessive egr meant the egr was possibly sticking open. Could it be that simple replace egr valve clear code fixed?
UPDATE I have a bad vacuum pump EGR diaphragm is fine.
 Post subject: Re: 99 Ford Ranger 2.5L P0402 excessive egr
PostPosted: Fri Jan 30, 2009 5:55 am
Replace the DPFE sensor with one from the DEALER. The code is for egr flow excessive but the problem is ford uses this sensor to detect and monitor egr flow, and the voltage gets out of range or too high at idle and the pcm detects what it thinks is egr flow when there should not be and sets the code.
PostPosted: Mon Feb 23, 2009 2:22 pm
I have replaced the DPFE with the dealer part but after clearing the code I still have 2 incomplete monitors evap and catalyst. I should have noted on the original post along with the P0402 code evap was incomplete. I'm not sure if I've completed the drive cycle.
Users browsing this forum: Gigabot [Bot], Google [Bot], Google Adsense [Bot], Yahoo [Bot] and 20 guests
