Now a Plugged Cat can cause that too. I was working on a Grand Am and started loosing power, can not climb RPMs, Overheated more than normal.
It threw the codes for Random Misfires and EGR Problem. I changed the Cat and is good as new.
Why the Cat? back pressure causes similar symptoms. Gases can not scape therefore goes back to the Combustion Chambers killing the ignition and lowering the Temps on the exhaust to certain degree and the cat does not get hot enough. Also, the last sensor on the exhaust detects the Temp that goes out of the Cat, if is not hot enough, it will throw a code.
I said to do the previous thing first since is cheaper than replacing a Cat.
Cats do not fail often, what makes them fail is excess of Oil, Fuel and Glycol. That could be an indication of Oil Overfill, worn valve guides and anything that can add oil to combustion chambers. A good look at the plugs can tell, if they are tan is OK, if is black, wet, deposits is not. If you have a leaking intake manifold, Glycol can make it to the chamber, or blown head gasket can, but you will notice a blown head gasket.
It could be that is old, but I had cars over 150,000 miles and never changed the Cat at all.
One test that I read on the web is to drill a hole on the Exhaust pipe before the Cat so gases can scape, if it improves is a plugged Cat. If not, a self tapping screw can plug the hole.
