The check engine light has been on for awhile with a evap code but the other day I came out started it up and it was running really rough, then it would try and correct itself by increasing rpm's. I have a pending bank 1 running rich code P0172. I thought it would be a misfire code considering the rough running, but its not. My freeze frame is below. Rpm:2720 Fuel System 1: closed Fuel System 2: disabled (Is this normal?) Calc Load 43.1% Coolant temp: 109 degrees Short trim:-13.3% Long Trim:7.0% Intake Manifold pressure 27inhg Vehicle Speed: 27mph
Any Ideas? I was thinking along the lines of a map sensor but wanted some suggestions. I had also noticed that it was mainly happening during heavy rain, and on the right front under the cowl the water drain tube was disconnected. Could this have a caused a problem? But now its constant and always running rough
Users browsing this forum: acan, Google Adsense [Bot] and 11 guests
