Hi All,
You folks are doing a great job as always!!
I took my Corolla 2002 (108000 miles) to 2 mechanics yesterday , since the check engine lights have been on since 2 months. I had purchased this car 3 months before and the Firestone mechanic said its safe to buy the car and has no problems. I am scared after seeing these details below
Code:
Econo-Lube says:
1 - P0133 - O2 Bank 1 sensor 1 - CKT Slow Response
2- P0420 - Catalyst efficiency below threshold - Bank 1
3- P0440 - Evap emission Control system Malfunction
4- P0441 - Evap Emission Control System Purge flow fault
5- P0446 - Evap Emission Vent Circuit Malf.
He estimated for 1 as 275$ for labr and part
He estimated for 2 as 566 for labr and part
Pep-Boys Says:
Code found P0441,P0446,P0133
Technician notes as follows:
Rec O2 Sensor B1S1 (Upstream) - Bad
Rec Catalytic Convertor - Bad
Rec Evap Canister (From Dealer Only) - Bad
Rec Evap Vent Valve located on air cleaner Housing
Rec Fuel Tank Pressure sensor (If not included with the canister assembly)
Rec Air Filter Package - Dirty
Rec 3 step - Oil Coked in Throttle Body
Rec R+I MAF sensor + Clean - Dirty
Rec R+I IAC Valve + Clean - Dirty
General Comments as follows:
Remove and Replace Oxy Sensor - One rear - $ 230
Remove and Replace Catalytic Convertor - $ 500
Remove and Replace Evap Control Canister - 370$
Remove and Replace Vacuum Swithing valve - Each - $ 30
Duty Valve - $ 54.82
Replace air filter package - 30$
Step Pro fuel package - 90$
Remove and Replace Air flow meter sensor - 120$
Remove and replace air valve - 90$
Total $943 for parts and $ 659 for labor :roll:
My tax payment is due on Dec 21 and he said I wont clear the emision test without making these repairs.
Folks please advise me since I am a big 0 when it comes to car related talks. Just dont know anything about the car parts.
1- Should I beleive the technicians words and estimates?
2- Can I give a try by checking net and Youttube on doing it myself?
3- If so then what all are the stuf I can do on my own and what all are the stuff which I need to go to a technician?
4- Bank 1 sensor 1 was replaced 3 months before and also the catalytic convertor. Thats what my friend said when he sold the car to me. Then why again?
Please advice what are the actions that I can take up and what are the critical ones. Are all the items need to be done?
Thanks,
Sunny
