It is currently Sat Nov 21, 2009 12:42 am
 Post subject: 1996 Dodge Ram Van P0132 Trouble Code
PostPosted: Fri Jun 13, 2008 10:59 pm
Was getting misfires. Changed plugs,wires,cap and rotor and new air cleaner. Ran fine then got trouble code P0132 changed the O2 sensor and still have the code. Reset it and still comes back. Any help would be appreciated.
 Post subject: Re: 1996 Dodge Ram Van P0132 Trouble Code
PostPosted: Fri Jun 13, 2008 11:16 pm
did you use the cheap bosch universal, is there two o2s? did you do a drive cycle, look this stuff up, it take at least five min. of batt. disconect to clear a hard code,wires to sensor on top of trany must be checked and there is a fuse to o2, I believe...hard to fix from here, there are some really good techs on this page but thier e. coasters and might be asleep, wait till tomowrow and check....all the other post pertaining to this issue it has been discussed all over here...good luck happened to me and the dealer said bosch no good......5.7 03 hemi :oops:
PostPosted: Sat Jun 14, 2008 2:00 am
ign. coil, check with digital ohm meter, unplug primary wires, ohms across terminals should be not much, then unplug secondary, put one lead of ohm meter inside, should be below 10,000 if o2 sen. good....coils can go bad. :D
PostPosted: Sat Jun 14, 2008 9:32 am
Check the circuit and connection to the O2 on Bank 1, Sensor 1 for voltage and ground.
Do you have a scanner to see what the O2 is doing?
Sure you used a good quality O2?
Good luck and keep us posted.
Users browsing this forum: Google Adsense [Bot], Yahoo [Bot] and 14 guests
