It is currently Sat Nov 21, 2009 3:21 am
 Post subject: 2000 chevy Impala LS - Code P0440
PostPosted: Mon May 26, 2008 1:54 pm
I have a 2000 Impala LS, 3.8 ltr. I have a P0440 code showing. On May 14, 2008, I could not put gas in my car . The shop scanned it and the same code came up. They replaced the EVAP solinoid and all was fine till May 25, 2008. I bought a code reader and its the same code. I cleared the code and removed and reinstalled the gas cap. Anyone have any other suggestions? Thanks. :?:
 Post subject: Re: 2000 chevy Impala LS - Code P0440
PostPosted: Mon May 26, 2008 3:02 pm
Site Admin
There's more P0440 tips here - http://www.obd-codes.com/p0440
OBD-Codes.com Administrator
PostPosted: Mon May 26, 2008 7:06 pm
did the replace purge solenoid under the hood or the one valve back by the tank?
PostPosted: Mon May 26, 2008 7:43 pm
I had the 1 near the tank replaced. Should the 1 under the hood be done as well?
PostPosted: Fri May 30, 2008 5:31 am
:?: I tightened the gas cap and reset the code hoping it was that easy. No go. engine light came on this morning. Now I'm a wrench turner only and venturing to the unknown for me. I did a freeze frame and this is what came up.
P0440
fuel sys. stat B1
cl, using H02S
Fuel sys. stat B2
0
calculated load
13.72 %
Coolant temp.
87 deg. C
St fuel trim B1
-1.57 %
Intake map
61.00 KPa
Engine speed
1949.50 rpm
vehicle speed
111.00 kph
mass air flow
24.11 g/s
throttle pos.
9.01 %
Can any translate this into english for me? Is there a site to translate?
Jeff (Mavrrrik)
PostPosted: Fri May 30, 2008 1:10 pm
I bought a new gas cap and ordered the solenoid under the hood as well. Any other suggestions if this don't work?
PostPosted: Sat May 31, 2008 3:08 pm
Also check for loosen, clugged or broken EVAP hoses near the tank and near the engine.
PostPosted: Wed Jun 18, 2008 1:47 pm
Update - its been 3 weeks, replaced the purge solinoid under the hood and replaced the gas cap - cost around $35 - all is good - no more code.
Users browsing this forum: Google [Bot], Yahoo [Bot] and 5 guests
