OK, sounds like the general opinion is that the Eastern Cat converter is a POS!
Some comments:
Jeff: you must work for a dealer! Some thoughts on that...I grew up in a garage and been fixing cars since I could get my head under the hood. So, I'm real picky about how things get done. I could go on and on about repair shops and associated screw ups. My observation is that most are not dishonest, just shoddy...or incompetent...or in too much of hurry...or all of the above. I guess I wouldn't mind paying the price if I actually thought they could do a better job than me, workmanship wise. So, I'm stuck having to fix stuff myself 'cause I don't trust anyone else...that's my "cross to bear"...plus I'm cheap.
Mohawkmtrs: to answer your question: Why not just get the OE cat and get it flashed? Well, because the OE cat is gawd awful 'spensive! Seems like I'd be out $800 bucks or so down at the dealer, plus the reflash. So far I'm into it about $250. That's a lot of beer. Plus I get to hear from you guys.
Now, if that secondary O2 sensor extender does the job I'll be out $265 total. And in the process, I'll have learned a bunch about P0420 problems.
Here's one for ya:
can anyone actually tell me what the reflash does? I understand what flashing is...you are loading new software (firmware actually) into the PROM (OK, I'm an electrical engineer)...but so far no one (on any of the forums I've checked) has actually described in detail what the problem is or what is actually being "fixed". Did the the firmware in the PROM/ECM get corrupted or did Subie come out with a new firmware release to correct problems in the original firmware? And if it's new firmware, what was changed in code?
Thanks again for the great responses. I'll check back.
