OK 2 questions, can the fuel pump be tested outside the vehicle at all, (we traced the return line as the GM diagnostic sheet said, funny thing is that the fuel pump is not listed as a cause for high fuel pressure anywhere on GM infosheet for the error codes.
I am awaiting my tester, a family member has a fuel pressure gauge they just shipped me for testing this. Can the vacuum system be at fault and not opening the regulator causing too much pressure to build?
I also read on Clubcav.com That my autozone purchased injectors a few people have had trouble that they were meant for 2.4l and not the 2.2 (autozone f*ck up)
ON top of that some of these have had the same problems and some have been coils or ignition module, and the pcm is making up for the issue and not regulating properly, some have bosch o2 sensors (which unfortunately i think i installed about 2 years ago). Some of the problems have been bad injector drivers in the PCM causing them not to drop fuel properly, and the car thinks its lean and adds more gas and the regulator is basically turned off (building too much pressure and blam)
The reason im questioning the fuel pump is that ive heard of them losing pressure but never slowly adding pressure, just seems unusual functionality for a pump but i guess its possible. But i will have my pressure tester shortly
