Post subject: Re: 1996 Nissan Sentra P0170, P0325, P1401
Posted: Wed Apr 30, 2008 3:33 pm
helo
The knock sensor code is a separately code that is resolved by changing the sensor. If you are having an EGR problem then could produce the P0171 but not necessarelly. What you want to try at first is to check the operation of the EGR valve, check if it is openning and clossing good, if it is working properlly, remove the EGR and clean the passages and look for carbon build also check the vacuum hoses that are attached to the EGR valve, check if they aren“t broken and if they are pulling vacuum. Do you have an erratic idle ? hesitation on desacceleration ? If you think the EGR valve is working properly then change the BVPT-valve (the one that is besides the egr valve).
Users browsing this forum: Yahoo [Bot] and 22 guests
