I just got a diagnostic report from my hand held tool thing and the code was P0325 Knock Sensor 1 Circuit (Bank 1). The only thing I hear wrong with the car is when I turn the key and for a second it hesitates to start but does start fine. Can someone please tell if they know what is wrong and if this is something I can fix myself. This report really confuses me. Too much information......thank you in advance........
I'd recommend getting a good tech to check it, it's unlikley a knock sensor is causing a hard starting issue unless the pcm thinks the timing is out when it isn't, a timing belt or distributor out on some engines will generate a knock code though and lead to a hard start so it's something to consider checking.
The Problem turned out to be a faulty knock sensor! If you drop it the inside will break as it has a fragile porcelain diaphragm. You will find that you will get random knocks in some or all your cylinders. A new knock sensor will run you about $160. I recommend you post a wanted ad on craigslist for a knock sensor. I got one for $25 bucks.
As for the other guys issues with the Honda stalling at start up I recommend you change out your starter. That issue went away when i replaced my failing starter.
Users browsing this forum: Google [Bot], Google Adsense [Bot], Yahoo [Bot] and 26 guests
