I have a ford f150 with a 4.6l. code reader tells misfire in 1 and 3 replaced all plugs, went to misfire in 3. checked wire for 3, looks good has resistance, checked coil, testing to specs acording to my repair manual. what else can i check?
I got about 1 yr/20000 mi on these plugs and wires, put new autolite xp iridium plugs in according to oriley parts guy is what book calls for. the old plug in number 3 had ceramic broken around eletrode but no other damage to it
just did a visual spark check, saw arc from number 1 but not 3, fixed that, pulled 1 and 3 plugs, everything looked good, swaped fuel injectors 1 and 3, erased codes, took it for a drive got same p0303 code
Users browsing this forum: Ask Jeeves [Bot], Yahoo [Bot] and 11 guests
