1998 Ford Expedition 5.4L 2WD, 175,000 miles, excellent condition. Problem is "High Idle Speed". In gear, running @ 900 RPM. Park @ 1200 RPM. Replaced throttle position sensor. Reference voltage of throttle position sensor is 4.06 V. Scan tool indicates 18% for TP Sensor at idle. Checked throttle body for obstructions. Clean, no problems. Butterfly closing completely. Checked MAF sensor. Found to be OK. Checked IAC valve. Found to be OK. Checked for vacuum leaks. Found none. Can the problem be the PCM? If so, what could cause it to fail? No other codes indicated.
P0121 Throttle position performance problem. P0122 Throttle position circuit low input. Check all related wiring tfor TPS for open and shorted conditions. Double check TPS for proper insallation.
Users browsing this forum: Google [Bot], MSN [Bot] and 35 guests
