danwaters32 wrote:
I went by autozone today to rent an OBDII cause my explorer has had some issues (97 5.oL)
It idles somewhat rough and when you stab the accelerator it almost stalls out and then catches and revs back up
The code I pulled was P0340 Camshaft pos sensor circuit malfunction
-where exactly is that located and how difficult is it to install?
As far as the EGR code (P0401) I have read something about the DPFE sensor being bad. Should I try that first and where is it haha? Im sooo frustrated cause the car is running like crap.
Re P0340:
There is a sensor driven from the camshaft which tells the ECU when TDC ,piston No1 firing stroke is occuring. The drive unit can fail (there are two types with Ford I believe) which means that no signal is generated from the sensor. Also the actual sensor itself (retained by 2 small bolts on top of the drive unit, which looks like a small distributor). Once you find the unit, take off the sensor & there should be a vane inside (hall effect unit) which stands up about 1/2" & is semicircular ,this is what triggers the sensor. If it's not there then you need a new CMP drive unit. If it's good then either the sensor is junk or the wiring connected to it is defective. The sensor on mine cost about $30. The drive unit I got from a wreckers for $45, it had the sensor on it ,which worked!! so I was able to return the new unused sensor I bought & the fix cost just $45....LOL.
HTH,
Aeroman.
P.S. Fords will still run with a failed CMP sensor but injector timing (SEFI) will not be firing as sequential but will go to "bank fired". Which is not quite as good but still works good enough to run the engine. I have heard of erratic idling when the CMP fails due to this very problem.
