Just a bit of info for those of you that are getting a misfire code PO303 on a 2001-2003 Sentra with the QG18DE 1.8L motor.
One of the possible causes is coolant leaking into #3 cylinder
. I have worked on two cars this week with a PO303 code. One is a 2002 Sentra and the other one is a 2003, both with the 1.8L engine. I did the usual checks (Vac leaks, plugs, coil, injector) and everything checked out o.k.. Both customers stated that the engine would run rough for a few seconds when starting the car after it had sat overnight. I duplicated the problem on both cars.
The next step was to pull the #3 coil and spark plug and apply pressure to the cooling system. After sitting with pressure for about 20 minutes I looked into #3 cylinder with a light and notice some liquid collecting on top of the piston. I determined it was coolant and realized that this is the cause of the misfire. I have not taken apart either engine yet so I don't know if the problem is a bad haed gasket or a cracked head, but I hope to get into the repairs soon??
So keep this in mind if you find yourself with a PO303 code on one of these Nissan Sentra 1.8L engines. I hope this helps someone out there.
