Approx 119,000 miles on vehicle. Absolutely no driveability/performance problems. Bought car (10/05) with MIL on in CA figuring it wasn't too serious. Drove car to & around Oregon-MIL went off w/out my doing anything-passed DEQ for relicensing, then some time later MIL comes on and remains on. Two years later due for DEQ/emissions test/relicensing & MIL is on, get codes P0325 & P0500 (knock sensor & VSS)-clear them & install new speed sensor (on trans-Wells #SU6475) along with new battery, starter W/solenoid, spark plugs; cleared codes & tried state emissions (DEQ) & registers "Not Ready" on Catalyst, Evaporative, and O2 Sensor checks. Continue to drive for work/shopping trips etc. and after 3-4 trips MIL comes on again. Clear codes 0325 & 0500 again, drive, and after about 3 on-drive-off cycles MIL comes on again. This time same 0325, 0500 plus P0600. Also, going back couple months or so, sometimes when starting the OD (Overdrive) dash light flashes several times & I might add the crusie control function would kick out after driving on crusie for only a short distance, mile to 2 or 3. P0600 I believe is AT Communication error? Is there a "Trans Comm Module"? - Where?
Took car to a "Foreign Car Specialists" for a fix: They pulled same codes and did some checking, like continuity and/or what I don't know exactly yet as they still have the car, but they said they could find "nothing wrong". Don't think they checked output of VSS nor resistance at knock sensor but I think they're both good. From here they said they could check each value or pin at the ECM which would take 2 to 3 hours and be
"expensive". Aargh! Not what I wanted. I'm scared to take to Nissan dealer for costs with probably lots of R & R's of good parts and still get nowhere. Plan to pick it up tomorrow and do what I can to check it out, connectors and the like, whatever I can do, but I sure could use some pointers and very grounded suggestions.
The car runs perfect, no pinging, misfires, starts immediately, no smoke, speedometer functions fine, havn't tried cruise control for a while, just that damned MIL on and the codes and trying to get it thru a sufficient "drive cycle" (whatever the heck that should be or include) to pass state emissions. I can't quite accept the fact the ECM might be bad as the car runs so good in all respects. Can I disconnect the wire terminals from the ECM and then reconnect just to clean them without messing up any stored data or anything? Sure could use some KNOWLEDGEABLE assistance on this problem, or direction to someone in the Portland, Oregon area who knows their stuff on this car. Thanks in advance for any assistance anyone is willing to share.
