| OBD-Codes.com http://www.obd-codes.com/forums/ |
| P0300,304,306 and P0171 and P0174 Code 1999 ford f150 http://www.obd-codes.com/forums/viewtopic.php?f=1&t=2991 |
Page 1 of 1 |
| Author: | jfdewalt [ Tue Dec 11, 2007 8:07 pm ] |
| Post subject: | P0300,304,306 and P0171 and P0174 Code 1999 ford f150 |
I have a problem here, i have a 1999 ford f 150 4.2l. I've been having problems with Po171 and po174, system to lean in bank 1 and 2. I've done alotof stuff, feul pump, fuel filter, fuel injector assembly kit,injector oil rings and intake gasket. and theres no leaks. I just had the fuel injector flush to see if that works. But after they did that they checked the codes before they earsed them and there was 3 more codes that have never been there before. P0300,P0304 and P0306 ( cyclinder misfire)Whats going on. |
| Author: | allen5795 [ Wed Feb 27, 2008 4:47 pm ] |
| Post subject: | Re: P0300,304,306 and P0171 and P0174 Code 1999 ford f150 |
find a line in to the egr ex tub find a way to open the egr a little and put some carbon cleaner in it the egr tub is stuck |
| Author: | jeff compton [ Wed Feb 27, 2008 4:54 pm ] |
HuH? Allen what are you talking about? jfdewalt has anyone checked or changed the MAF yet? Are you sure the intake still doesn't have a vaccum leak? I'd be hard pressed to believe carbon in a tube is causing that many dtcs on that truck! |
| Author: | jfdewalt [ Wed Feb 27, 2008 8:57 pm ] |
I have a new MAF sensor and the shopsays there no air leak but i'mgoing to bring it to other shop. |
| Author: | louiesy1988 [ Thu Feb 28, 2008 5:22 pm ] |
i have this kind of problem before with my 2001 Ford Expedition the dealer want to charge me $250 just to correct the problem, already told them about the code(the misfiring of cylinder). i went home borrowed my friend pocket scan OBD II (in which i have my own now. anyway try to check the boot of your sparkplug there might be some electricity from the sparkplug that is leaking that's what i found out on mine. and don't get to the dealer it will cost you a lot$99.00 for one piece at Autozone it only cost me $9.50/a piece....good luck |
| Author: | louiesy1988 [ Thu Feb 28, 2008 5:24 pm ] |
to : jfdewalt >>>> if you are using a KN&N filter take it out and clean it again and DO NOT use too much oil..it might correct it. |
| Author: | jeff compton [ Thu Feb 28, 2008 9:34 pm ] |
causing the lean codes though? |
| Author: | louiesy1988 [ Thu Feb 28, 2008 10:39 pm ] |
exactly..because there is no enough air going thru the filter..as far as i know it's like that casue i clean mine and never got the lean code anymore. |
| Author: | jfdewalt [ Fri Feb 29, 2008 10:21 pm ] |
I dont have a K&N air filter |
| Author: | jeff compton [ Sat Mar 01, 2008 9:10 am ] |
I think the timing is out on the camshaft on that side of the engine! |
| Author: | allen5795 [ Wed Mar 12, 2008 5:54 pm ] |
thats was a wiring probulem on the f150 and 100 cars ago and the randum misfire is a tricky one p0300 to day i was working on a e150 van and found a vac leak bottom intake |
| Author: | louiesy1988 [ Wed Mar 12, 2008 6:42 pm ] |
if you're talking about 304 check it's boot for the spark plugs i have that problem before they is a leaking electric current going to the plug...but if it is 171 my remedy on that one change your air filter or if you have a K&N clean it...because on PO 171 the air is too lean |
| Page 1 of 1 | All times are UTC - 7 hours [ DST ] |
| Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group http://www.phpbb.com/ |
