It is currently Sat Nov 21, 2009 6:24 am
 Post subject: 2000 civic P0135 code
PostPosted: Sun Dec 02, 2007 8:50 pm
Howdy, Boy I could sure use some help. I have a 2000 honda civic that the service engine light came on. Since there was a sale on ODB-2 readers I thought I would take a shot at figuring this out myself. Read the code P0135 o2 sensor bank 1 heater. So I replaced the o2 sensor upstream of the cat. converter. Prior to replacing it, the car would run okay , but did not accelerate as well as prior to the service eng light. Also when you came to a stop after moderate speed (35-45 mph) engine would idle rough and almost, if not die. When I read the code, the reader had the EV and C feilds still flashing. After replacement of the o2 sensor. Car accelerates nicely, but still develops a rough idle. What should I check next? Are these flashing feilds indicative of something? I suspect I may have a bad PCV valve, or is my converter on its way south?
Thanks for the help I am kinda lost at this point.
 Post subject: Re: 2000 civic P0135 code
PostPosted: Thu Feb 19, 2009 3:11 pm
You convertor is cracked where the O2 sensor screws into it .Major problem with these .I've changed hundreds of them .It will cause many driveabilty problems.Hope this helps :)
Users browsing this forum: Google Adsense [Bot], Yahoo [Bot] and 4 guests
