Post subject: P0101 code on a 1999 Jetta TDI, sluggish, CEL showing
Posted: Tue Nov 20, 2007 1:24 pm
My CEL recently went on and at about the same time, my jetta started acting sluggish when excellerating. There is some hesitation when first taking off , as well.
Having owned a TDI before, I figured it was the MAF and replaced it,but still sluggish. However, the after market MAF doesn't "snap" onto the connector like the old one. I used some duct tape to get a snug fit, but no difference. I discussed this with Dealer , and they said that connector could be bad, and that I should have bought VW parts (from them) so they would fit!
Any thoughts out there? The OBD code lists Vaccum hose, throttle body intake and BARO/MAP as also possible sources of this problem....
I'd try a correct MAF unless you can diag the other options more thoroughly! Can you put your old MAF back on and get a reading to compare against your new one?
