It is currently Sat Nov 21, 2009 3:59 am
 Post subject: P0306 Cylinder Misfire 1999 Buick LaSabre
PostPosted: Mon Nov 19, 2007 3:04 pm
Code P0306 indicated misfire on Cylinder 6.
A little background on this vehicle.
Just bought it from my neighbor who bought it new and only has 60,703 miles. Runs absolutely fine. This vehicle has not been run for 2 years. It just sat in her garage.
When I tried starting the vehicle it would turn over but would not fire. I sprayed a little Starter fluid in it and it started up fine. Ran rough for a very few second then leveled out. The light came on while I was driving it across the street to my house.
What do you think is the most logical problem. I have been reading your forum concerning other posts related to this code. I am not a mechanic by a long shot.
I thought I would check out the #6 cylinder spark plug but man it is way on the back of the engine. I could not be so lucky for it to be on the front so I could remove and check it out.
I am thinking that since it set up for 2 years it most likely is a plug problem, I hope.
Thanks
PostPosted: Mon Nov 19, 2007 3:49 pm
if they are original then it's quite likely an ignition wire is bad although after sitting for that long an injector could be gummed up as well! I'd start with a tune-up using premium quality ign wires and the correct AC delco plugs and try a fuel system treatment or cleaner if the code persists!
Those cars are known for injector problems!
PostPosted: Mon Nov 19, 2007 5:06 pm
Thanks for this information. I will try the injector cleaner first before replacing the wires and plugs. If code comes back after I have ran the cleaner for a while and reset the codes, then I will replace the wires with GM band wires and manufactured recommended plugs.
I will post the results.
PostPosted: Mon Nov 19, 2007 5:09 pm
I noteced that Auto Zone has Prestone Fuel System Cleaner for about 6.88 with a rebate of full purchase price.
Is that a good cleaner? If not what do you reccommend as I know there are a lot of this type product on the market?
PostPosted: Tue Nov 20, 2007 7:00 am
replace the plugs and wires anyway! they're likley junk, they're almost 10 yrs old! Seafoam is supposed to be an excellent fuel additive!
Users browsing this forum: Alexa [Bot], Google [Bot], Google Adsense [Bot] and 6 guests
cron
