It is currently Sat Nov 21, 2009 5:38 am
 Post subject: 99 ford crown victoria-- p0305
PostPosted: Mon Nov 12, 2007 5:56 am
Need some help
I drive a 99 Ford Crown Vic. The car drove fine on the way to work. That evening the car would not idle. Took it in and had the IAC Motor replace and found out that the intake is leaking. Replaced the intake and now I had two trouble codes p0350 (?) and p0305, the other code p0350 is no longer there. I had the coil pack and spark plug replaced. Changed the fuel injectors around and that did not change anything. Sprayed fluid around the intake- I heard no change also.
What could be the problem?
Thanks
Bill
PostPosted: Mon Nov 12, 2007 9:24 am
wrong forum and likely a plug, wire or vaccum leak problem still! if it happenbed after the intake was done get it back to them!
PostPosted: Mon Nov 12, 2007 10:06 am
Site Admin
Moved to correct forum.
Users browsing this forum: Google Adsense [Bot], Yahoo [Bot] and 5 guests
