It is currently Sat Nov 21, 2009 2:35 am
 Post subject: 03 dodge ram 1500 5.7 p0132
PostPosted: Thu Oct 18, 2007 1:00 pm
hi, i got a 2003 dodge ram 1500 w/ a 5.7 w/ 30k miles. it has a p0132 o2 code. replaced both, still came back. looked at pin fit at sensors and computer. wiring looks good. any help?
PostPosted: Thu Oct 18, 2007 1:40 pm
P0132 indicates that the signal wire is shorted to voltage. Unplug the sensor and using a voltmeter check voltage on the signal wire harness side. If the voltage is present with the senosr unplugged and key on engine off, then the wire is shorted to voltage somewhere. If it leaves when unplugging the connector, then the sensor is at fault or the installation.
PostPosted: Thu Oct 18, 2007 4:10 pm
did you use generic cut and splice replacement 02's?
 Post subject: dodge p0132
PostPosted: Mon Oct 22, 2007 1:21 pm
thanks for help, ended up being a bad aftermerket o2 (1/1). got dealer one.
PostPosted: Mon Oct 22, 2007 3:45 pm
no way! :roll:
 Post subject: Re: 03 dodge ram 1500 5.7 p0132
PostPosted: Wed Jun 11, 2008 1:07 pm
me too,I love my truck,03 ram 1500 hemi standard cab 2w dr street truck,auto,man it IS fast! same problem,code 132, replaced both o2,same exact stuff, funny though, if I remember to rev and hold at 1000 rpms whenever I start it,lite dos.come on and every things fine, I suspect I need to change plugs, dealer told me to 20000 mi. ago, also I used the cheap universals, I cant believe bosch is junk, ive read all the post,anybody else?
Users browsing this forum: Ask Jeeves [Bot], Google [Bot], Google Adsense [Bot] and 10 guests
