It is currently Sat Nov 21, 2009 3:51 am
 Post subject: 97 Jeep Wrangler with p0171 p0131
PostPosted: Fri Sep 14, 2007 10:11 am
I have a 97 jeep wrangler with 107000 miles. i just got it back from the jeep dealer, the replaced the steering box and sensor but a day later i get 2 codes p0171, and p0131. I took it to my exhost shop and the pipe between the cat and muffler where the u-bolt is, is very loose so they will weld it up but my jeep as far as i know doesnt have a MAF (p0171) so that code eludes me, but as for the o2 sensor i am not exactly sure what that code means.
PostPosted: Fri Sep 14, 2007 10:14 am
you don't think you're o2 code could be causing the PO171 dtc, if the 02 is stuck lean you could generate that lean code, as well vice versa could happen, a lean problem like a vaccum leak, low fuel pressure etc could cause an 02 code and a lean code! You need to do some diag.
PostPosted: Fri Sep 14, 2007 4:56 pm
Like Comp said, make sure they didn't accidentally leave a vacuum hose disconnected.
PostPosted: Sun Sep 16, 2007 1:05 pm
Hi...
You have sometime of leak. Ckeck all the intake lines.
Users browsing this forum: Google Adsense [Bot], Yahoo [Bot] and 9 guests
