It is currently Sat Nov 21, 2009 5:21 am
 Post subject: 97 suburban 5.7 2 wheel drive 1/2 ton P0122 and P1122 codes
PostPosted: Mon Jun 25, 2007 6:10 pm
I have a 97 GMC Suburban 5.7 1/2 ton w/tow package and 165,000 miles. I just purchased the vehicle and replaced the intake gaskets and upgraded the FI unit also. It runs great now but over the weekend I pulled a car trailer with a small load of branches to the dump and for the first time since I have owned it it shifted real hard from first to second. At the same time the SES lite came on. I went home and dropped off the trailer and shut the vehicle off while unhooking the trailer. When I started it back up the SES lite was off. So I went to Avance Auto to have the code read and it came up as P0122 tps pedal position sensor a circuit low input and P1122 tps pedal position intermittent ckt low voltage. It has not done this since. Is it possible the two are related? I have seen in other posts on here that it might be possible and if so what should I do? A new TPS is less than $50. Should I just replace it or is this not the cause of the hard shift?? Thanks for the help,
ccnova
PostPosted: Tue Jun 26, 2007 6:47 am
you think it's related to having the trailer hooked up or the weight increase?
PostPosted: Tue Jun 26, 2007 7:45 am
I am wondering if the hard shift is related to the tps error codes. I have read that the tps is a very important sensor and can affect lots of things if it is working incorrectly. Is this true? Thanks for the help,
ccnova
PostPosted: Tue Jun 26, 2007 10:14 am
sure it is, the sensor and the trailer could just be a coincidence! A sensor is a realtively cheap guess at this point if you want to try that!
PostPosted: Tue Jun 26, 2007 5:44 pm
I had never put the two together I just thought it was my luck to have two things go bad at once. But I also just hate to guess and throw parts at something. Is there a way to look into this better? Thanks for the help,
ccnova
PostPosted: Wed Jun 27, 2007 6:37 am
a scope on the tps signal!
PostPosted: Wed Jun 27, 2007 4:48 pm
Sorry I dont have access to a scope. I will probably just replace the tps for now and hope nothing else pops up. Thanks for the help!
ccnova
Users browsing this forum: Google [Bot], MSN [Bot], Yahoo [Bot] and 5 guests
