It is currently Sat Nov 21, 2009 6:34 am
 Post subject: P0125 in a 2001 Ford Ranger
PostPosted: Wed May 16, 2007 2:02 pm
So here are the symptoms:
P0125 - Insufficient Coolant Temperature For Closed Loop Fuel Control
Heater does not work, well it works on a hot day, not on a cold day.
Temp Gage on dash does not read anything, sits at below COLD.
For what I read the possible solutions are:
Check Coolant Level - Done
Replace Thermostat
Replace Coolant Temp Sensor
More Info:
I've reset the light before and it comes back within the week.
Its been this way for over a year.
ANY HELP!?!
Thanks
~Rob
PostPosted: Wed May 16, 2007 2:53 pm
so you haven't replaced the the thermostat?
PostPosted: Wed May 16, 2007 3:24 pm
Nope, no actions yet except reseting the SES
PostPosted: Wed May 16, 2007 4:01 pm
Well then flush the coolant, replace the thermostat and rad cap and check the cooling system for any leaks or combustion leaks, like a blown headgasket, but likely you just have a thermostat stuck open or a rad fan that stays running all the time! Buy the thermostat from your Ford dealer to be sure that you get the correct heat range because too cold a thermostat rating will trip that code and give you poor heat output, flushing your heater core wouldn't be a bad idea either!
Users browsing this forum: Google [Bot] and 10 guests
