It is currently Sat Nov 21, 2009 2:34 am
 Post subject: 2003 Jeep liberty renegade 3.7 v6 P0306
PostPosted: Thu Apr 19, 2007 12:10 pm
i keep getting P0306 codes (cyl. 6 misfire) on my 3.7l and it doesnt like to fire up it will crank and crank if i let off and crank again it will fire right up, then sometimes it will spit and sputter then fire up like it was carb'd. if i take a drive and go shopping and come out it does the same thing crank crank then fire up in like 10 seconds or so.
i changed the plugs from the factory NGK V-Power to Autolite Copper it didnt help swapped the #6 coil to the #3 coil and it wouldn't start swapped the #3 with #1 and it started but ran rough so i bought a new coil pack for it and replaced the #1 which was originally #6 (hence the code) and now it is doing the same thing i am still getting a P0306 (cyl 6 misfire) code.
when i pulled the plug on #6 it had some oil on the top of the threads where the socket would grab the nut, but the rest of the threads and plug were clean normal looking color.
a friend said it may be a cam/crank position sensor.
does anyone have any idea as to what it may be? i only have the powertrain warrenty cause it is certified preowned and they want $45/hr for diag. i didnt do a comp. test yet
if you need more specifics lemme know
PostPosted: Thu Apr 19, 2007 4:03 pm
45 dollars for a door rate is probably too low to employ techs competent enough in driavability. Try using the correct spark plugs for starters and have the compression checked. I have seen some camshaft failures on the 3.7's and injectors plugging up. You could try switching the injector to another cylinder and see if the code # changes to a different cylinder. Assuming the compression is good. A flat cam lobe won't always show up on a compression test. Cranks sensors are a common enough failure on those engines but they don't normally give just a misfire dtc and they can break off in the engine quite easily if you're not careful. I've fixed enough liberty's too know they aren't my favourite Jeep!
PostPosted: Thu Apr 19, 2007 4:09 pm
comp test showed 150psi +/- 2-3 across the board couldnt do a leak down as we dont have the proper equipment the comp checker holds the pressure.
ill see if i can get the injector off and swap it to the opposite side Cyl #1 so it will be easier to change if that is the problem
plugs have around 2000 miles on em, and some oil on the threads of #6 only, rest of the #6 plug is normal the other plugs look a little ashy grey in color on the tip and contact center diode is bright white.
it since has started up fine but i know there is a problem somehwere
PostPosted: Thu Apr 19, 2007 4:31 pm
if you have a noid light stick on the injector plug to #6 to be sure it's even being pulsed by the pcm before removing it and switching it.
PostPosted: Thu Apr 19, 2007 4:35 pm
yeah dont have one but i could rent one i suppose or buy one they're like 40 bucks for the kit
Users browsing this forum: Ask Jeeves [Bot], Google [Bot] and 7 guests
