you jusy have to remove the throttle body, and all the hoses too it and clean the throttle blade and all the ports with either a pipe cleaner and some wd-40 or a little bit of intake cleaner and some compressed air. The Dpfe sensors on fords cause all kinds of codes when they go bad and I magine if the car was driven long enough you'd have the p402 code return. You could try getting an
http://www.alldatadiy. subscription if you're having a hard time finding a manual but Autozone should be able to source you a chilton or haynes manual for your car. I've never tried autozone's website with there z-net system but maybe it'll give you some pictures. A new 02 sensor is hardly a waste on that car. Probably 75% of 02 sensors fail or wear out and never generate an 02 code and unless you install the wrong one it should never make the car run worse or use less fuel so think of it as good maintenance! A failled egr valve itself I suppose can generate 02 readings that are weird as well but anyone that knows fords knows the dpfe's and throttle plugged are almost always the source of egr codes, not the valve. Are you sure there isn't a blown fuse somewhere for the 02 sensor circuit. I've seen cars come in with 02's unplugged that only generated the staying at centre type codes, no codes for heater failure, lean or rich etc!
