jeff compton wrote:
... I'd be leaning towards a likley valve problem.
I don't seem to have the continuous smoking issue of the older 3.0 valve seals, but...a couple times last year, I was pumping out lots of smoke when idling around a parking lot in Colorado (7000 feet above sea level). But haven't noticed that since. I also got a weak catalytic conv code when at high elevation, but that has not come back since returning to the east coast.
I do use a quart every 800-1000 miles, but I'm pretty sure all of it is leaking out the valve covers while running (never get more than a couple drips on the driveway.) I can smell the burning oil dripping across the exhaust at times when stopped.
I guess my question is, what happens to the valves? Is it just a simple issue of wear for any engine. And, at this point, is it really worth doing anything about it? The engine seems to run fine. I think I can continue to get thru yearly emission inspections by clearing codes about 1 week before inspection. (giving time for self tests to complete.)
I am on the original catalytic, fuel pump/filter, injectors, hoses. Have had timing belts, water pump, transmission, muffler replaced. Only hose issue was needing to cut an inch off of the fuel line where it jumps from the strut tower to the engine. Started to leak at the hose clamp.
I have always been skeptical of gas additives. But it seemed to work that time.
